I've had this Corsair XMS Pro memory (with the activity LEDs on top) and realized I'd never really tried to OC them. So tonight I thought I'd do some more tweakin' to see what I could get. So far I'm running at 231MHz (2.7v, finally found it through Corsair's help forum, 'RamGuy' told someone to manually set their ram to 2.7v, 'cause that's what they're supposed to be at), and if it runs its paces through Orthos, I'll probably step it up a little more. How much is everyone else seeing with these modules @ stock voltages? I'm not sure I want to go much over 2.7, if at all.
Also, my mobo isn't very friendly when it comes to ram speed settings. The FSB I can change in 1MHz increments, but the speed for the memory has pre set speeds (i.e. 100MHz, 133, 166, 200, 216, etc.), so I've had to resort to setting it to 200, moving my multi up 0.5x, and turning the FSB down.
Originally I was running @:
240 FSB
10x multi
4x HTT
166 ram
To get back to the same speed, I had to go to:
231 FSB
10.5x multi
4x HTT
200 ram
That's probably my only major complaint about this board. I can manually edit individual timings but not the speed of the ram (does this come across as a WTF to anyone else??). I haven't updated the bios since I got the board Apr.'06 though, so I might look into that.
240 FSB
10x multi
4x HTT
166 ram
231 FSB
10.5x multi
4x HTT
200 ram
