Corsair water/pump combo in custom loop?
Tengis
Ive got an h50, large radiator, another pump, and hoses. Seems like it may actually work rather well. I could splice another Corsair block/pump in there for the video card.
Could easily set everything up in an hour or so. Worst case scenario it sucks and I just wasted some time.
Anyone done this?
I have a friend that converted 3 corsair water kits into a "Custom Loop" H100i Water Block+Operative Pump in CPU, H100(regular H100) Waterblock +Operative Pump on First GPU With Dwood Bracket+Fan, and H70 Waterblock with inoperative Pump its using all radiators h100i radiator on top, h100 radiator bottom and H70 Radiator Rear.. He said its working perfect that way the whole system with just a little reservoir.. he also told me he didn't used H70 pump (disassembled) due to seems to be much weaker than H100 and H100i pumps... and he only had to spend money on custom hoses and fittings. the real pain he said was only to find a good cooling liquid to avoid corrosion from cooper blocks + Aluminum Radiators..
i think in your case the worse case scenario are the H50 pump may cause a flow bottleneck if are much weaker than the custom Pump... you can try it and see how it work..
You could probably do it but why? You will be better off going with a normal custom loop that uses only copper.
