limitedaccess
- May 10, 2010
I have a Corsair VX550 which as 2 cables with 3 4 pin molar connections that have large tabs, the issue is the the tabs make it somewhat problematic for cable management.
I'm wondering if it would be safe to remove the 4 pins from the molar and wrap each end individually in electrical tape? Since there is no way I need to use all 6 molars. I can then reinsert them if I do end up needing them.
