Corsair Twinx 3200 LLPT
The Lurker
What do you guys think?
I want to get a matched pair, 2x512 for my system.
Hows this memory compare to everything else out there.
TwinX is matched pairs already. Corsair makes great memory, but it may be cheaper to buy two of the non TwinX sticks that are identical to those. Compare the prices.
I dont want to mess around with non matched memory. When it comes to my computer i tend to buy quality.
I would just like to know how well this overclocks and how its performance compares to everything else on the market.
This is the most expensive set of corsairs on newegg, without having to go to the 4000 or registered series memory.
Perhaps you should do a little more research. It's the same memory. Ever hear of something called Marketing?
Absolutely not.
Ever hear of pre testing.
It's the same memory. Same exact chips. You don't need pre-tested memory. If you buy the same sticks, it WILL work, gauranteed. Why pay for something you can do yourself?
Cause i got a lot of money to spend.
Does it matter really?
I want some information, thats all.
Heres some freindly advice, dont count other peoples money.
Here's some even better advice. Don't ask for advice if your not willing to listen to it. I got a lot of money to spend too, but I'm not foolish with it either. Having a lot of money doesn't make an intelligent spender.
Originally posted by st4rk
So do I, but my IQ his high enough in that I can identify a ripoff when I see one.
Troll.
i believe you meant to say 'my iq IS high enough....'
just a note ;)
up here in canada, twinx is cheaper than 2 separate mem modules in some instances, not always though.
Dont waste your money on the low latency Corsair stuff. It really isn't any better then the normal 3200C2. The 3200LL doesn't use BH chips so its not going to be any better then the rest of whats on the market that uses CH-5 chips.
Personally i would get the Mushkin PC3200 lvl 1 1GB kit for $205. I'm ordering another set for my Gigabyte board im getting this week and its pretty well the best memory you can buy. Mushkin has always been the best for top quality products and service. They'll all run 2-3-2-5 so why spend all that money on something labled as Low Latency when its really not.
I ran it @ 2226 without issue , it was ch5 but revision 1.2 and for some reason it rocked. I moved to Muskin Special becuase i can get 2225 @ 2.75v. I must admit that its not just about speed. I just cant resisit the beauty of the Mushkin Heatsinks. Roflmao
PS: I got the 2226 on the Corsair with voltage set to auto.
Did you run Memtest86 and Prime95 after setting it to 2-2-2-6? CH-5 doesn't like to have its tRCD lower then 3 and it will usually always cause the system to be ither unstable or cause errors.
I will say this, I did not experience system instability but I did run beter 3d mark scores at 232-6
I typically dont run memtest unless I think there is an issue. In fact I only recently used it after seeing the name in this forum.
I was compelled to use it on my new Mushkin. I was getting random reboots. The anomalie corresponded with the addition of the Mushkin. The memory passed. It turned out to be my video driver but I digress. I guess my point was I believe the Corsair to be pretty good stuff. I must admit i dont overclock nthe fsb. I have not felt the need. Nothing has come up that my current configuration has not been able to handle at stock speeds
Confesssion: I did oc my Video card a tad to get the 3d mark scores
I use Corsair XMS in all my systems. Here is a screenshot of one computer that has been running SETI for months with these settings.
Just so you guys know, if you go to newegg and look at the price of single stick of 3200 LLPT 512mb, and buy two seperately it turns out to be more then if i were to buy a matched set.
Therefore i suggest you think before you open your mouths.
http://www.newegg.com/app/ViewProductDesc.asp?description=20-145-428&depa=0
at 157.50 x 2 it comes to $315. I paid 289 for a matched set.
I love capitalism, Thats correct, a package deal (two sticks) is always cheaper thus 2 birds or in this case dims in the hand are better than 3 in the bush. Thats how the seller sees it.
Dude what version cpu-z is that? Or is the temp overlay anther utility?
