Corsair reccomendng the wrong memory for MB?
Bikebro
I'm past due and more then ready to build a new pc. I choose a MSI P965 Plat motherboard to go with a E6600 and 8800GTS. While my knowledge is well above that of the average PC user I'm not into overclocking and the less I have to do in the bios the better. I thought I had everything together till I looked at memory. I went to the Corsair site and selected my motherboard and it came up with 2.1v memory. Now the MB states 1.8v. Seems like this would cause some problems and I wonder if the computer would even boot with that installed. Any suggestions or ideas on what to do?
much of the ddr memory needs ore than 1.8v to run stable. If corsair says 2.1v then run 2.1v. My memory ddr1 runs at 2.70v as per corsair but the initial spec was lower when i bought it. I run 2.65v and all is good. This high performance ddr2 memory always seem to require more than the 1.8v. Some people with these new ddr2 motherboards are having trouble running certain ram due to their motherboards bios only going up to 1.8 or 2.0v.
If corsair says 2.1v id run that. They know their product.. and make fine ram even if dfi boards dont like them. My corsair ddr1 pc3200c2 ram runs great and o/clocks to 255mhz at 2.65v..............
I have a different motherboard (P5N32 SLI Deluxe), but...
When I upgraded from 2 gigs of Corsir to 4 gigs, I was getting random reboots every 20 minutes or so. Posting on the Corsiar boards, I was told to up my RAM voltage to 2.1. I did so and have been rock slid stable since.
Corsair seems to do a lot of testing, with all different combos- they know their stuff. If they say go to 2.1 volts, I would listen, and I would bet it would work/you will be fine.
Also to note, when I made the change in the BIOS, it highlighted red- Corsair support said don't worry, and I made the change. Rock solid.
My only thing was they have the same type of memory at 1.9v and it cost less. It goes from 4-4-4-12 to 5-5-5-12 though. It looked to me like they just wanted me to buy the more expensive product.
