TwistedMetalGear
- Jun 19, 2005
Is this actually necessary for overclocking the Dominator series of RAM? I have it, but I disabled it due to noise and vibration. Thing is freakin annoying! You know when two or more fans are out of sync and you get that "pulsating" sound/vibration? That's exactly what I'm experiencing with this fan. Who knew that three tiny fans can cause such a racket.
So currently I have it attached but unplugged since my system is not currently overclocked and I'm running in an air conditioned room. If I do decide to overclock, do I really need to hook this thing up? Or will the RAM be fine on it's own with its super duper heat dissipating fins?
Or maybe I should install a fan speed controller for these things?
Comments/suggestions?
