Corsair HydroCool 200EX
FrostyAMD
Got one of these and moving to AMD 64 trying to find either 64 adapter or may have to mod something to fit. Any ideas hate to discard this.
Maybe change the block, you can still keep the rest of the system, but just change the cpu block if you really can't find the mounting for A64
hmm... any block suggestions ones that would work well or better than the standard block??? i'm a relative noob to water cooling.
the swiftech 6000 is great for both low flow and high flow configuration at a very reasonable price. Please do consider the swiftech block comes with 3/8 barb size. You will need to either stretch the current tube over it or find adaptor for it.
