h100 or h80i?
Have they fixed the thread stripping problem on these where the screws go into the radiator?
Hasnt the H100i been superseded by the H110?
I have a push/pull setup and have already taken the cooler off twice to clean the case and all the components in about a year's time. There isn't really a chance to strip the threads as all 8 screws (2 fans) can't screw all the way to the thread limit. So it's not an issue for me.Have they fixed the thread stripping problem on these where the screws go into the radiator?
when I saw H80 I was so hoping this was an 80mm AIO solution
... Please add in the h90 in that list if possible.
I have one of these, after replacing an H100 that had the fan/pump controller die. It works quite well, as long as I don't hook up the USB connection or use the software.
The software is horrible. The latest version hangs every time the system boots up, no matter what OS I use. I've tried it under Windows 7, 8, and 8.1 and had no better performance. At least the latest version is better than the older ones that would randomly crash the OS or cause drastic hangs. I have yet to see a version that does what it is supposed to do. It even does this without the cooler attached by USB, so I can't blame that. It is just bad software.
The USB functionality is even worse. I have had this cooler for over 2 years now, and across four motherboards and two platforms, Core i7 3930k and Core i7 4790k with X79 and Z97 boards, if the USB connection is connected when the system powers up, it hangs on USB init. I have tried all versions of the firmware, and it simply doesn't matter. I have tried it with powering up the system with it disconnected and then hooking it up as the OS loads, but the software problems listed above have kept me from doing anything with it.
I love Corsair and most of their products, I have 4 sets of memory, two power supplies, and two cases from them, but this one is a horrible mess.
I woudn't mind replacing my current AIO with this one, but i would have to get a new case too. That sorta kills the deal. I imagine i would do something very near 5ghz with this current chip of mine. Almost makes it worth it, but i can't honestly justify another 200-400mhz for ~$150+. Heck of a price though, that's a nice deal.
just if you have delidded.. if you haven't yet, isn't the cooler the limiting factor but the crappy TIM intel used in ivy bridge and first gen haswell chip... my 3770k can do stable 4.5 at 1.240v. or 4.6 at 1.256v. but after that point if i want for example 4.8ghz I have to bump voltage to 1.34v. which skyrocket the temperatures as I have mine un-delidded and my temps at 4.5ghz aren't so bad..
I've considered de-lidding as well, but i'm a poor son of a gun and i can't afford to buy a brand new chip if i manage to nick her to death. My chip does do 4.6 @ stock volts @ LLC1 so i really would be on the fence about raising volts just to get a couple hundred more mhz i woudn't notice.
Edit: I'd be curious to see how the H100i does with a full 4 fans in push/pull config...
I have a H100i that I put in my last build (Aug 2013 - wow that's a long time). I agree that the software is really bad, but it is not causing any hangups for me. I pretty much leave it at the default. I run a mild overclock that the ASUS AI suite configured and my temps are good. I used to move it to performance mode when I gamed, but I don't any more - temps stay good even with the fans running low.
If I really wanted to tinker, I would move the fans over to the MB headers and use the AI suite to run the fans, but I am getting good performance, so there is no real need to push it. I am currently running mine in a push configuration, with the fans blowing thru the cooler and out the top of the case.
Right now I am at 27C on a 4770K just typing this. Can't complain.
sorry bud, but i highly doubt your chip can do 4.6ghz @ stock volts. not even the better golden chips can do that.. you can do 4.0-4.2ghz at "stock volts" even some great chips can undervolt at those speeds, but 4.6v at approximately 1.13v-1.16v is just impossible, the only fact that you apply Load Line Calibration you are adding voltage. can you post a CPU-Z under heavy load?.
you are probably downloading the wrong corsair link software (and that's a corsair fault infact) you have to enter in the Corsair h100i (or h80i) product page and download the software directly there, if you download it from the general download page it cause issues and that's because the Link software for the h80i/h100i isn't the same for the corsair commander mini..
Has anyone had the chance to test the new H110i GT (which is now in stock)?
