Corsair HX620W
Blackjack
My main rig has a Corsair HX620W currently powering it specs are as follows:
i7 920 @ 3.4 Ghz
6GB (3x2GB) OCZ Platinum DDR3 1600
2 x 400GB WD Drives (RAID 0)
BFG GTX275 (stock)
Would it be safe to add another GTX275 for SLI on that power supply? If not are there any recommended PSUS?
It should be enough, although it would be a good idea to go with a 750W PSU if you plan on doing any more overclocking.
should be enough so long as you don't o/c cpu too high. Probably 750hx is better choice
