corsair hx520 problem
purple_haze
my older mother the nf7 wont accept the connecter on the hx520, is there some kind of adapter for me to use to make it fit and work with the nf7. i just wanna use the psu right now, waiting for my funds to replenish for me to get my dirty hands on core2duo parts is making me ancy and i dont wanna have the psu be a paper weight for the time being.
the 20 pin, there's a 24 pin the corsair. You just plug it in and leave 4 pins on one side open.
You bought an ATX12V PSU for an ATX Socket A board?
Hmm.....
If you're talking about the main power connector, take a look at the 24 pin and see if the last 4 pins "break off" to make it a 20-pin.
Otherwise, do as Bbq suggests and see if it'll plug in with the extra four pins hanging off the edge.
