Corsair HX1000w
Sepe
I have new asus rampage extreme IV, i7 3960x, GTX 680, DDR3 32 2400mhz to all sources if supported Corsair HX1000w food that was old?
thanks
tengo nuevo Asus Rampage IV extreme, i7 3960x, GTX680 y 32GB DDR3 2400, si es compatible Fuentes Alimientos Corsair HX1000w funciona?
Gracias.
I have new Asus Rampage Extreme IV, i7 3960x, 32GB DDR3 GTX680 and 2400, if supported Corsair HX1000W Power food that was working? Thank you.
It's a good power-supply that should be able to power just about anything.
Well, I've been running my RIVE with an i7 3820, a full water cooling setup and a GTX580 Classified Ultra 3gb for a couple months with my HX1000w with zero problems. Since the 680 uses less juice, I'd imagine you'll be cake and pie.
Gracias.
Si
lol at the food translation
Stick three 680s in there and you'll still be fine.
