Corsair HG10
Gotta admit that thing does look pretty damn cool. Not sure if it would be all that worth it if you have one of the higher end 290X's like the MSI Lightning or the Sapphire Tri-X. Anything else and that could make a very nice addition to your rig. Cooler temps and quieter fans too. Not bad for $40 I suppose.
The nzxt uses a 92mm fan to cool the vrm but there isnt any heat sinks for the vrms (you need to buy those separately). The hg10 uses the stock gpu fan to cool the vrms and you don't need to buy vrm heat sinks. You will need to change the fan profile because it doesn't spin up to cool the vrms because the gpu is cool.
You just made Corsair some money Trick0502. Thank you!
Would be nice if Corsair sent one to Kyle and the crew to be tested.
That is sexy! So looking at the video on the Corsair product page, it seems that it uses the stock fan from the 290 / 290x to cool the VRAM? Doesn't the NZXT use an aftermarket fan? Which would be better if I get the above correct? Never took my R9 290 apart so I could be completely wrong. ;)
The NZXT fan is a 80mm and a bit loud at full speed. Since I put heatsinks on everything I run it in low. Many people replace the stock fan on the NZXT. I'd like to think the stock blower is better off your card like what Corsair did.
This thing took Corsair almost a year over the original launch date. IIRC they were putting a lot more effort into VRM cooling than the competitors.
I am interested in this for the future, although I am going to wait for a good review.
i have the nzxt, and I feel like it would blow the corsair out of the water. first of all...a stock fan (ROFL). Having to create custom profiles and ALWAYS worry about your vrm temps is very annoying.
With the ramsinks, and my own aftermarket 92mm fan on the brackets, my vrm idles in the 20's. when I game, its the low 40's.
I can add +200mv and the temps still would not break into the 60's on my vrms.
I would, at the very least, buy thermal pads and stick them on the vrms, this way there is better contact between the plate and the corsair plate.
Using a stock fan is a major turnoff.
The vrms on the corsair will never be good as the nzxt, since nzxt allows you to put custom sinks on the vrm.
No offense but imo the corsair design is much more user friendly and more aesthetically pleasing
Plus having to put those tacky ass heat sinks on the vrms is laughable. The corsair unit has a uni body heat sink that cools the ram and vrms and you don't have to worry about heat sinks falling off the card.
Not a bad price. I hope this extends to the other corsair card mounts due out in 2015.
i would not jump the gun on the corsair mount until VRM temps are revealed.
if you need some convincing on holding off, here are pics from a post I made a while back, from my crossfire 290s with nzxt bracket:
idle temp:
Load temp with +100mv:
as you can see, there is tons of room for overclocking through adding even more voltage. I wouldn't be surprised if you could add +400mv and still have respectable temps on gpu and vrm.
if you are doing this simply to reduce noise and not add voltage for high overclocks, then I would say go with the corsair, since it seems much easier to install - by this I mean, you won't have to install ramsinks, which, is actually very easy and simple...but then again, If your going simply for nosie reduction, do you really want to depend on the stock fan?
Well looking at it, it seems to use a blower-style fan implementation that sends air parallel across the PCB but the air doesn't quite make it out the back vents, whereas the NZXT just uses a regular fan blowing air perpendicular to the PCB which definitely doesn't vent out back.
The other thing is the NZXT hides the tubes better.
Looks like a solid choice for AMD users that don't want to bother with additional little heatsinks.
solid choice? did you not see my pictures? My temps with the nzxt spits diarrhea all over the corsair bracket, and I am using +100mv.
you have sinks on yours
because it provides better VRM temperatures than their stock solution. (as per the review video linked above)
you make it seem like adding sinks is akin to performing surgery.
it literally takes 5 minutes to add on the sinks.
It does not look like you can add sinks to the corsair bracket.
Good luck trying to add voltage for high overclocks with 85C vrm temps on stock volts.
no i don't
plus the extra money for the sinks themselves
it's a good thing i didn't say you could
85c is lower than what you would see with the stock cooling
-Happy Kraken G10 Owner
no i don't
the nzxt currently cost 19.99.
Gelid is 13.99
ram sinks you can buy for cheap.
total ~40-50$
Benefits: very low vrm temps, allowing for added voltage and higher overclocks.
Corsair bracket:40$
My 290's, with a stock reference cooler, before I upgraded to water cooling, had vrm temps in the 60's.
It is a given that you will NOT be able to overvolt wit ha vrm stock temp of 85c.
Why waste money on this then?
-Edit: you can actually buy the nzxt bracket on tigerdirect for 9.99 after a mail in rebate. ROFL.
Do you work for corsair or something?
I'd love to know how you managed that with the NZXT bracket, and how you verified the VRM temps.
I'm using the NZXT bracket + 92mm fan + EVGA front-plate + additional ramsinks and my V RM temps can easily begin approaching 100c while benchmarking. This has been verified with an IR temp gun pointed at the back of the PCB directly opposite the VRM chips.
With that said: Real-world gaming doesn't generate VRM temps that high, and even if it did, these VRMs are supposedly rated for up to 120c... but obviously cooler is better...
Gelid is 13.99
total ~40-50$
Corsair bracket:40$
I got my g10 for $14.99
grats.
I'd like to work for Corsair. It's actually pretty funny, most of their support reps have "Beard" in their names, like Redbeard, Yellowbeard, etc. I'm sure they wouldn't mind a Bigbeard86.
Maybe I wasn't clear when wrote this at the end of my post
I like my G10 very much and you can go pound sand.
grats.
you're missing the entire point of the discussion.
you had stated that the HG10 is a solid choice for AMD users, and I countered it is not, as the trivial caveat of using additional VRM sinks with the NZXT is not anywhere near sufficient to recommend the HG10 over the NZXT. I provided you with sufficient evidence showing how the NZXT can be the far more optimal choice - this does not even include the very poor choice by Corsair to use the notoriously loud, stock AMD fan, coupled with the dilemma of setting custom fan curves and keeping your eye on VRM temps, in order to prevent potential overheating.
I used the gelid kit, with thermal pads between the vrm and the heatsink.
If you did the same, you should not be getting temps anywhere near that.
The nzxt bracket without any sinks gets temps in the 90's. If you added sinks, you did something wrong (poor contact?)
What do you mean by EVGA front plate? how are you using that on an AMD card? You are talking about NVidia? Because the discussion here was about AMD.
I have no idea what kind of vrm sinks are available for the NVidia card (which model do you have)? How is it setup? The front plate covers the entire card, and the vrm sinks are underneath? I don't know how that setup would be - does it trap more heat than it transfers? having gaps like that is usually a bad thing.
AMD cards allow you to read vrm temps through GPUZ. You can reply or PM me for more specific info.
I was discussing the NZXT G10 bracket, which works on both AMD and Nvidia cards. So, yes, I'm talking about an Nvidia card.
We all have VRM cooling to worry about, no need to be exclusionary :rolleyes:
It's GTX 780 with the EVGA front-plate installed on it. This plate is screwed-down and uses thermal pads to make direct contact with the RAM and VRMs (there are no "gaps"). This plate serves as the only source of VRM cooling for EVGA cards that come equipped with an ACX cooler, so EVGA seems to feel that this is plate alone is adequate for maintaining normal operation.
There are additional copper ramsinks thermal-epoxied to the front-plate in the RAM and VRM areas. This was done to increase the available surface area for cooling WITHOUT epoxying anything directly to the graphics card. The card can still be returned to a 100% stock configuration with nothing but a screwdriver.
So you're trusting the built-in sensors, that's... Interesting... I personally wouldn't trust those to be 100% accurate on any card.
On the up-side, the slop on built-in sensors tends to be near the low-end (they have trouble giving accurate idle temps), so you might be ok trusting them for load temps.
Why would I not trust the sensors? You do not trust your cpu temps, or gpu core temps?
the only reason review sites use a thermal gun to read vrm temps on NVidia cards is because there is no other way to do it.
It might not be 100% accurate, but it should be very close. Reviews that did use thermal imaging did not reveal much of a difference between sensor/camera readings.
I doubt putting those sinks on top the plate do anything at all.
I would look into removing the front plate, and finding someone that has designed custom vrm sinks for the card. For Vram/vrm, you can always uses double sided thermal tape to mount the heatsinks.
For the gelid kit I use, the larger of the two heatsinks can be screwed into the screw holes in the card. the other heatsink is simply attached to the vrm with double sided tape - I have no issues of it falling off, it is stuck on there pretty tight (you can lift the entire card by pulling on that one (taped) heatsink).
Of course I don't fully trust them, why would you? Anyone who's actually tested them against a real temperature probe knows that the built-in sensors you usually find in consumer PC hardware have some serious slop, especially noticeable at low temperatures.
And then consider we're running these chips close to red-line as far as heat is concerned... I'd rather be safe and always verify with a known-good probe than trust a built-in sensor at face value. I mean... if I have the tools to verify it's trustworthy on-hand, why risk taking it at face value?
I'd still expect an external temp probe or thermal imaging of some kind be used for verification in a proper review.
Dropped VRM temps in furmark from 105c to 95c, repeatably. Just taping them down didn't do much, but epoxying them to the plate with Arctic Alumina did the trick.
I have two of those front-plates (one that's un-modified), so it's easy to test. They do work, and it was a hell of a lot easier (and more reversable) than trying to stick those massive RAMsinks down on top of tiny VRM chips.
Have not seen a single custom-made VRM cooler for the 780, and even if one existed, it's a bit late in the product's life-cycle to consider it.
Would make more sense to start looking at the GTX 970.
My copper heatsinks look ravishing. If installed properly, they wont fall off.
