Corsair H80i $50 AR
These things are unreliable. They are notorious for springing leaks and I can guarantee you , you do not want to be putting one of these things in your PC not being sure of how their fittings are.
And just how many have failed for you? I've had 3 (all corsair) for over a year and none have leaked
They're Asetek coolers, same as Zalman, Antec, NZXT, Corsair H55, H70, etc. If they were frequently exploding it would be more endemic than just Thermaltake.
To be exact? 2
The first one ruined by motherboard and they would not replace it despite it being their part that ruined the board.
The second one, I knew what was happening then, so I yanked it out with little liquid making it onto the board before I had a chance to clean it off.
The replacement I received from the second one I sold on Craigslist to someone else would prefer to deal with it. Personally, I will never buy another manufacturers pre-fab'd water cooling solution. Besides they're not any better than some high end copper heatsinks and certainly not better than a custom water cooled solution where you are aware of the fittings.
This is solely my experience and simply a warning to those who would walk down that path with one of these. Don't say you weren't warned when it leaks, fries your main board and they they don't replace it for you, because they won't
To be exact? 2
You must have terrible luck.
I've been running an H100 almost 24/7 for the past 2 years on high without issue.
