Corsair H80 Intel brackets
you don't need a backplate for x79/x99 motherboards as the boards have already a backplate.. you only need the standoff for 2011 boards which are already included in the mounting kit. every thing will be exactly the same as your 1156 except you will be skipping the mounting backplate part and go straight with the standoff and pump/block mount.. its easier =).
Yup, as mentioned, the main thing you need to look for are the LGA 2011 standoffs (which are included but people tend to lose them).
No backplate required.
Well this is interesting. I just looked at MSI site, and the XPOWER AC motherboard comes with a special OC backplate for mounting the water cooler.
"Mounting your LN2 pot or other extreme cooling solution can be a real hassle when using the stock X99 backplate, because it blocks the necessary screwholes. That's why MSI created the OC backplate. A low profile backplate which is perfectly flat and gives full access to the screwholes needed to mount your extreme cooling solution. The OC Backplate generates optimal mounting pressure. This leads to lower CPU temperature and maximizes overclocking results. You can also combine the OC Backplate with the MSI Delid Die Guard for even better mounting and cooling results."
