Corsair h115i question
Guarana [BAWLS]
I am building a new rig in a Phanteks Enthoo Evolv case with a fan hub on the back of the tray.
Is there any disadvantage to not plugging the radiator fans into the sockets coming off the waterblock vs using the fan hub instead?
Thx
nope, you can run without any kind of troubles or issues your fan separated with your desired fan controller or directly to the motherboard.
The RPM lead is for the pump speed. All you lose by not connecting fans to the pump block is Corsair's fan control functionality.
Of note you likely do want the RPM lead hooked up as a lot of motherboards won't boot. Plus if something does go cattywampus with the miss pump you'll know!
I plugged the block into the CPU Opt header on the board. The fan hub has the CPU FAN bit.
Def good to monitor!
