- Feb 11, 2013
well.. short story: another victim of the corsair h100i pump issue...
Long story: I received this system almost exactly 1 month ago, and well all perform flawless for 3 weeks.. after that point i started to see a slighly increase on temps every day on normal gaming.. then i proceeded to make some test with p95, Intel linx and aida64, my actual i7 was slighly oc'd turbo to 3.9ghz on all cores, 4.2ghz single core and well my worries become a reality when prime 95 sent my chip to 90C, I immediately stop all the test and started to check for any leak then touch the tubes one was cold, the other veeeery hot, so well, fans running good, radiator was fine, tubes fine and no leaks.....
Story final: pump broken, i'd contacted to the store where I bought the will cover the warranty process (excelent.. so i avoid the RMA process with corsair) but they have to test few days the product.. no problem.. i bought a cheap Hyper 212evo they offered me for like 10$ while they make the product check and test.....
what I found? what a hell of excelent product the hyper 212. I made some couple of test with the stock speed on p95 for like 2 hours, heck.. it perform almost the same as the corsair h100i, just one degree of diference... on a 30C room temp (i choose this, cuz was the last controlled room temp I made the last test with the h100i)..
this are my temps with h100i:
The thing its.. was my H100i starting to damage days ago without realizing?... or how this cheap hyper 212 can perform exactly the same as a h100i?. tomorrow i'll start a new round of test with the chip oc'd as same as was the h100i and my normally room temp.. to compare.. i guess i should receive much higher temp with the hyper 212 on oc'd temp.. im truly at this point dissapointed with the h100i.. when i receive a new one im thinking in sell it U_U..
