Corsair H100
It says it works with H100i v2 and H100i GTX. There is a different bracket for the H100i. Neither of them mention an H100.
Is your current mounting bracket a circle or a square?
The square mounting bracket is here although it doesn't say it works for AM4. I'd email them to make sure.
It looks like you use the square bracket and tabs to mount it to the stock AMD heatsink bracket. So if you already have an AM2/AM3 bracket it should work for AM4.
