Corsair H100 or Custom Loop
Enthusiast Extreme
Hey guys, I am somewhat new to liquid cooling and I need some help deciding on what I want to cool my cpu with. I dont really want to mess with custom kits because I have never done one before, and I have had an h70 before and liked it hence why h100 looks so appealing. What should I do?
One thing to consider is custom loops in most cases can give you better performance, but it can come with headaches.
I would say go for it on the H100 if you have a case where you can mount it.
Coolit makes a similar system that uses a 240mm radiator, [H] does have a review on it. I wouldnt expect the numbers from that to be totaly different from the H100. Heres a link for it.
http://www.hardocp.com/article/2010/07/21/coolit_eco_c240_performance_review/
Well today I cancelled the order for h100 and decided to wait for asetek chill water c2011 that comes out in August. It has thicker rad and also better tubing.
