Corsair Graphit 780T,
shadowj
I have a Corsair Graphit 780T, unfortunately I can't mount fans on the bottom ( for the RTX 5090 )
Thinking about replacing it, what would you recommend?
I'm using in the front of the case, my old NesteQ FanMax, I want to keep it.
Wish I could mount something like this, between the PSU and GPU. Would that be possible ?
Any advices are welcome, thanks
I have that case (in storage at the moment), and it has great air flow, so I wouldn't worry too much about installing fans on the bottom to cool the 5090. Are your temps high on the 5090 now? What model 5090 do you have? I have run 4090's in that case and no issues with temps.
RTX 5090 Palit Gamerock.
I wanted to keep it as cool as possible, that's why I asked.
Thank you
Reactions: Niner
Thank you
Sure thing. As long as those front fans are bringing in a decent amount of air I think you’ll be fine with that case.
I have 4 SSD and 2 HDD's
I could get ride of both HDD's but I'm not sure where to replace the SSD's, so in this case, front fans are bringing in a better amount of air
Reactions: Niner
