Mike Clements
Gone but not Forgotten
- Oct 31, 2006
Here's some info directly from my buddy RAM GUY:
Weve received some feedback from users with motherboards based on the Intel P45 chipset who are unable to run 1600MHz stable, even with modules that are rated at that speed.
Testing done in our labs has concluded that users looking for the best overclocking results at 4GB on a P45-based DDR3 motherboard will have best results with these parts:
TW3X4G1800C8DF
TW3X4G2000C9DF
TW3X4096-1600C7DHX
The following part may top out at a speed short of 1600MHz on a P45-based motherboard:
TW3X4G1600C9DHX
The modules that we found unable to achieve 1600MHz on a P45-based motherboard were able to achieve 1800+ on an Asus P5E3 Premium which uses the X48 chipset.
This issue is isolated to only motherboards using the P45 chipset. Please note, this type of issue is something thats often able to be remedied with a BIOS update from the motherboard manufacturer.
Well continue to update this thread as more information becomes available.
TW3X4G1800C8DF
TW3X4G2000C9DF
TW3X4096-1600C7DHX
TW3X4G1600C9DHX
