Corsair CX 450 enough for RTX 3050?
wandplus
The Newegg calculator says total 390 watts with motherboard, 1TB M.2 SSD, 2TB HD, one DVD-RW (probably irrelevant), 3 case fans + on the heatsink, 2 sticks of RAM and i5-11500. I haven't looked at the power limits for the CPU in the BIOS but I want to run stock speeds on both the CPU and GPU (RAM will be native speed of 2666 MHz even though the Crucial Ballistix RAM is 3200MHz lol).
It should work just fine. Do you have the CX450 already? If not I would look into a 550 or 650. To give you some head room.
I have the CX 450 and did not anticipate the 130 watts of the RTX 3050. I had assumed falsely that when the go down to smaller chips the consumption would go down.
Should be fine seeing how the CX450 can max 37.4a on the main 12v line.
