Corsair C70 help/advice
miller330i
Need help/advice! I only have one shot at this for the next few years.
I haven't made a water cooled rig in a long time. All my knowledge is outdated.
I have an AMD FX-8350, an ASUS Crosshair V Formula-Z motherboard, two GTX 670's (non wc)) and 16 gig of 4 modules of G Skill DIMM DDR3-1600 memory.
I have a Corsair C 70 case, a BR player/recorder, Kingwin LZP-1000 power supply and a dual reservoir made by XSPC.
I want to water cool this rig and make it as quiet as possible.
I don't know what is out there and build quality as far as WC components go. I want it to be reliable with the best performance possible. I need all the other components to make a dual loop system.
I might be watercooling the MOBO if I can find the right parts. Can I cool the memory as well?
I have used EK and XSPC stuff in the past.
Whom is the best performance for the buck as far as a component supplier goes now?
Thanks!
Jeff
A H110 for the CPU and a couple of H60 or H70s for the GPUs? Honestly, I was one of the pioneers of PC watercooling and I see no need to return to that level of piecemeal custom stuff except for aesthetics. The Corsair stuff will give you 95% of the performance with 33% of the cost and 1% of the hassle, plus give you a warantee. Basic airflow through the case that you will need anyway for the radiators will give enough cooling for all but the most overvolted/overclocked components.
