Corsair AX850 Sleeved Cables
If i were to buy the newer generation cables corsair cables for like the AXI series and just switch the plastic connector pieces to fit the pin-outs on my AX850, would it work? or are the cables in each sleeve different in some way?
You can switch the pinouts and it'll work. As long as the connector keyholes are the same.
Not very.
Try this site: http://www.moddiy.com/
You can ask them to custom make a set for you.
yep, paying someone to make cables or making them yourself is your only option it looks like. CP-8920010 is the model number for the white set, doesn't show up in any stores in google search unless you want to pay about 400$ from some random vendor on Amazon.uk.
im pretty bummed about that. decided to go with the black set and maybe re-sleeve one or two rows in each set white later on. Really wanted to pull the trigger on this site tho
http://www.icemodz.com/home/
guy was super helpful and was on live chat right away
