Corsair 800D wcing setup
Quak3R
Haven't built a wcing setup in years, last one i did was in the haydays of the xp-2500m when they used to work in desktop motherboards. I just bought the 800d and flustered on going back to wcing, but Im a little out of the loop so far , these are the specs i want to go with . IM only doing a single cpu loop for the time being
XSPC RX360 95 bucks
http://www.frozencpu.com/products/8523/ex-rad-146/XSPC_RX360_Triple_120mm_Radiator.html
for just the cpu atm , I think maybe this is going a little overkill going with a triple rad, but the fact the 3 fan holes on the top really bother me; maybe for asthetic purposes.
Laing DDC pump/res combo
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=59_367&products_id=4511
now this is racking my brain, and probably a real noobie mistake to do, but with the laing ddc pump have a lot of force to pump all the way to the triple rad mounted at the top if the pump is going to be mounted right behind the hotswap bays are? or does anybody have any different recomendations on pumps/res/rads?
cpu block is up in the air atm until i figure out if i am sticking with the q9550 or going back to amd
If there's a chance you'd wanna go dual loop, I'd consider getting this reservoir with this pump. At last that's what I did...until I said what the hell and decided to stick both loops in before getting the second vid card heh.
20 ft of head on the mini swiftech thats not bad. I looked at the laingddc because its hailed all over these forums just wonder if either will work just fine on the triple rad overhead
