Corsair 800D Build
Misfit79
Hello all,
Just wanted to post some pics of my new case, and maybe get some suggestions for things that I could do to improve the look of it. So far I'm really happy with the case, very solid build and great performance, and I love that I have the room to hang the freezone elite vertically. This allowed me to use the rear fan as an intake which has helped airflow. I'm upgrading from a thermaltake armor and I still cannot belive how much more room this thing has!!
Feedback is welcome!
Thanks for viewing/commenting.
Very nice build. I can't wait for mine to get here, God doesn't want me to have this case or something. 3 orders at 3 different vendors didn't go through, but supposedly it is in the mail from an ebay sale.
Are those lian li CD bezels? Can you show how you mounted them if they are. Love the look with the CD bezel in place!
Hi KrylonArt
Yeah they are Lian Li Bezels. I was hoping there was enough clearance to just drop them in but in the end I had to cut off the entire right angle bracket and then cut about 3mm's of the remaining aluminum off.
the side screws actually snap into the 800d's front bezel holder's, but sit to far forward, so I used some double sided tape at the front of the bezel to space it so they sat flat with the rest of the front.
pardon the 1minute paint shop demonstration :)
before:
after:
Thanks for the interest!
is it a triple fan blow hole on top? if so, you think a triple rad can fit up there nicely? or is there a different setup for water cooling? I see what appears to be tubing holes on the tray leading to the level with the psu.
Yeah theirs a ton of room on the top for a triple rad - there's also tube holes on the bottom shelf, and on the upper back of the case to mount another rad externally.
