CompMage
- Sep 7, 2003
As the title suggest, I'm stripping a 750D down for painting and need some suggestions on the last small part before I can get it washed and in the paint booth.
On the upper 5.25 Drive area there are plastic latches to hold the optical drives and what not in place. I've looked it over as much as I can and do not see how to remove them without getting the dremil out. (Not that I've not considered just pulling the whole bay area out. As that is what will happen if push comes to shove.)
Thanks!
Thanks!
