Im getting ready to pull the trigger on a 700D. Current system going into the case will be:
MSI Big Bang XPower
I7 930
6 x 2GB Patriot DDR3-1600
GTX260 / 8800GT
Thermalright Ultra 120 eXtreme
Thermaltake Toughpower 1200 / W0133RU (modular version)
OCZ Vertex 60GB SSD
4 standard hard drives
2 optical drives
Lamptron FC-2 fan controller
(1) My main concern is will I need extensions for the Toughpowers cables? ModRights Single Braid cables look very nice, and I plan to use them as necessary. The type and quantity needed would be appreciated.
(2) I will install an external water cooling loop later. Can some measure the diameter of the pass-through holes, without the grommets? Im planning on using Koolance VL4N quick disconnects and they are 1 in diameter. So I need to know if they fit through the pass-through holes.
(3) I have plenty of 120mm fans, and will outfit the case with as many as I can. Will use fan extensions to run to the Lamptron FC-2 Fan controller.
Any advice or opinions are welcome, and appreciated.
MSI Big Bang XPower
I7 930
GTX260 / 8800GT
OCZ Vertex 60GB SSD
2 optical drives
