Corsair 650D Side Mesh Panel - Need help!
refraxion
Hi guys, I was wondering if anyone knows if the Corsair 600t sidemesh panel would fit the 650D side panel perfectly? I ask because the mod that posts on the Corsair forums can't even give a definitive answer.
So I come to you guys, I hope someone has done this before. I'm thinking of buying the 600t side panel with mesh insert and hoping that mesh insert would fit perfectly with the side panel slot of the 650D.
Any input would be much appreciated, thanks!
