Corsair 620HX
jridge2778
Anyone know where you can get a Extender cable for the 8pin for the corsair 620HX? The cable is to short to route behind the mboard try.
Thx
Contact Corsair about it. They're sending, for FREE, the 6 + 2 cables required by some of the latest generation of video cards. Maybe they'll do the same for your cable. Couldn't hurt to try.
Mr.Wolf, quite sure the OP is referring to the 8pin +12V cable :)
Mr. Wolf knows this, he just said since Corsair is sending out FREE 6+2 pin PCI-e cables maybe they will send an extender, worth a shot.
