Summers618
- Dec 26, 2006
I'm constructing my first build right now. I have ordered everything and so far, the only item that i have received is my corsair 520hx power supply and several Yate Loons that I had. Everything else wont be arriving until January second due to the weekend and the new year. The problem I am having, being a newbie at this, is that i think my power supply was DOA. I took it out of its packaging (props to corsair, very nice!) and wanted to test it out due to excitement of my first build coming to life finally. I plugged it in and flipped the switch on the back. Nothing happened. No spinning fan on the supply or lights if there are on this supply (i dunno). I thought to myself "that makes sense, its not supplying power to anything, so the fan doesn't need to run" I then proceeded to hook up a fan. I'm 99% sure i hooked all the cables in right, being modular and all, and flipped the switch... Nothing... Same as last time, neither fan works... "Must be the outlet" i thought to myself. I have tried about 3 outlets that I know work in my house... No luck. Is there some special step that I am missing, am i being a stupid newb, am i hooking the cables in wrong, or is the supply actually dead? Any help will be much appreciated.
