Corsair 450d
Pivo504
Anyone own a corsair 450d? Is it possible to mod those ugly feet that hold it up? The case does not feel solid and rocks because of those feet. Is this a defect made by corsair? Appreciate the help.
Thanks for the reply. I Luke the case but something about the feet make it look odd..I will check ti see if the rubber feet are missing. I'm almost debating on selling case for a fractal arc midi r2 but not sure if the quality is better
Thanks for the reply nasgul. I have a similar rig to yours. How are you going to setup the water cooler? Like I said I like the case for everything but the goofy looking feet that hold the case up...I wish there was a way to mod them and make them look better. Nasgul I'm surprised you didn't go with a stealth front drive? I think it would make the case look much cleaner! Still looks great just need to add sum nice lighting! BTW what red fans are those? I think the arc midi r2 is the same size as the 450d,both mid towers?
Nasgul what is the difference between push and pull setup? I've read having push and pull is best but not sure how it needs to be setup.. I have both my fans on the h100i as exhaust fans. Another thing I noticed is with the rad and fans I cannot place the dust filter flush with the case onthetop.
Earlier in your post you said your doing push but later your post says your doing push and pull? Can you post a picture of how your fans r setup on the rad ? Thanks
I own a 450D myself and love the case. Just get a H110i GTX and those 2 140mm fans on top will do the job just fine.
Nasgul can you post a picture of your water cooling setup and fans, appreciate it thanks
So, the Force is not strong with that case....
Nasgul mine is setup the same as yours. However the bolts from the rad get in the way on the top the the case when putting the dust filter on...
IMG_3708_zps8znmbylh.jpg~original
Is the red item a PCIe SSD?
