- Oct 17, 2000
Just built a new system in the corsair 275Q quiet case, but noticed after assembling this may not work as well as I thought... it's getting way to hot for comfort, looking for any suggestions.
The case, see picture, is designed to be ultra quiet, both side panels have the sound dampening material, the front panel is solid with the air being taken in through the 1 inch gap in the front, and then exhausted out the included 120mm rear fan.
There is currently 1x 120mm front fan, and 1x 120mm rear fan, that's it. And that's all I thought I would need...
The Corsair 275Q does include the top removable panel, so that 3x 120mm fans can be installed but I so far I've left this on.
Parts are:
3700X using stock Ryzen Wrath Prism cooling, I didn't see the need to upgrade, seems quiet and decent, if I can just shut off the unicorn lights.
Gigabyte Gaming-X 570
evga 2080 ti ftw3
16gb corsair lpx (with ryzen xmp)
evga 750 gold
1x m.2 pcie 4.0 ssd (run's a little hot)
1x m.2 pcie ssd
1x 7200 spinner
1x 5400 spinner
Finished building the system last night, installed 10, drivers, pulling down 1903, and then I noticed the top of the case is really warm... too warm for comfort, considering I'm just pulling down 1903. As soon as I checked the rear 120mm fan, I noticed it was very hot. Great... heat issue already... and I'm not even gaming yet. So I yanked the top shroud off, exposing the 3x 120mm fan grill and within a short time things cooled down. So now I need to figure out how I can make this quiet case work, with all the components, and keep it quiet. I'd rather not go AIO water kit because the pump WILL be heard. The front has 3... or maybe it's 2 120mm fan mounts, along with the top 3 I could install, and then 1 on the back.
The 275Q case has a PMW 5-6 fan header I can use, but I didn't because the included cable is the shortest I've ever seen, and the issue with that is the stupid Gaming-X board only has 2 system fan headers... Really Gigabyte?? and to make matters worse, both those fan headers are located on the back of the board, 1 up near the 8pin CPU plug, and the 2nd between the I/O and CPU. I'm going to pick up a 4 pin extension today, obviously I'm going to need some more fans, but any sugesstions are welcome, cheers [H]
Oh, also, 10-15 years ago I would spend hours, days OC'd the crap out of my stuff, taking the Athlon XP 1600 up to 2.53ghz at ridiculous voltages, running a Celeron 533 at over 1ghz using a peltier, good times. Now with a career and family, my time to tinker is short, so I'd rather spend what time I do have gaming. That said, I AM that guy who now leaves the BIOS settings at default... yes, I'll admit that.
I don't have time to look through the 5 million voltage options in the BIOS vs the 20 I had on the ABit BH6... So, if there are BIOS settings that will help, by all means please make the suggestions. Thanks guys! Oh, yes I did set the AMD XMP profile for memory, (3200), but that's pretty much it...
Parts are:
evga 2080 ti ftw3
evga 750 gold
1x m.2 pcie ssd
1x 7200 spinner
1x 5400 spinner
