Corrupt file and folder on a RAID5
thecazz
Hi
I helping a friend with his windows 2003 server that he have a RocketRaid 1740 with 4x2TB WD Red disk that he run RAID5
The program say the disk is ok, and I have format the disk in NTFS.
But when we copy files to it windows 2003 say some file is corrupt and folders??
And I can't even run a scandisk, it try a little but after a while it just stop?
I have no idea how to fix it or have to find what wrong with it.
Hmm maybe only I have that problem :)
Is that any way a good program that can run a scandisk, win2003 does not do that on the RAID5?
In Server 2003 you are going to want to run chkdsk if you can afford to take the volume offline for reboot/check, or vrfydsk if you don't want to/can't bring the volume down.
