Corrupt Data from drive recovery
SlickEddie
Hey guys,
I have a big problem. I accidently formatted and reinstalled windows Vista on my wife's laptop and lost all of her data. I was able to get the most important data back (55GB), using getdataback, however, when I go to open any of the files, they are all corrupt. Is there any program I can use to fix these files?
Thanks
I use filescavenger 3.0 I remember it tells you if the files are good or not.
I'm afraid if none of the files will work after being recovered, that they have been at least partially overwritten. :(
But seing how you have 55GB worth of stuff, I cant see how this would be true. Maybe they were just unsuccessfully recovered. Try a different program, maybe the one I mentioned.
