I am a little confused on flashing the bios for my K8N Neo2 to fix temp reporting issues. On the websites how-to
(http://www.msicomputer.com/support/BIOS_award.asp) it makes it sound like you would flash from a floppy. But when I downloaded the bios, it also had a readme that specifically said to not flash from floppy (http://216.158.218.35/edoc/bios_uploads/7025v12.zip).
Which one is correct? And also, they have a way to flash the bios for a non-FAT filesystem. Would I do that method since I use NTFS?
Sorry for all the questions, I just want to make sure its done right. I never will learn if I don't do it.
