correct install order?
sdk
after a reformat, what is the order for installing your vc drivers sp1 dx 9 and all that stuff
going away for 2 weeks makes u forget.
There's no real "order" that I'm aware of, but I would recommend installing SP1 first, then DirectX 9, and then whatever else you have.
well there is a order that has been proven to get the max performance
I remember reading many times.. that you should definatly install first SP1, then Chipset drivers, then Videocard drivers.. after that.. anything goes
