Correct E6600 temp?
superballz00
Im getting 37/34 load temps running F@H 24/7 and even tried orthos overnight and temps were around that too. When I did prime95 on each core temp wemt cup a litlle, around 39/37. If I check temp with speed fan the highest temp I see is 45-47. Does that sound more like my cpu temp or is the 45-47 the chipset temp?
Where tha hell did u get that Intel Thermal Analisis Tool?
My on water TDX runs 39 Idle and 47-48 full both cores Load. My water is bad...damn PrimoChill ICE got all blury :(
TAT is core temp.
As you are at your highest temperature 40C under the core temp threshold of 85C (where you start to do damage), I really wouldn't worry about it lol
Im using the zalman 9500 so I was surprise to see load temps under 40. Can the readings be wrong?
That's no big deal, you're running the E6600 at stock. The Zalman is an excellent cooler despite what people say.
Why don't ppl like the zalman? I was gona get the scythe ninja for the same price but it won't fit my case. BTW is it normal that I can wiggle my zalman a little? It only let me secure it with 2 screws so makes it less secure in my opinion. Also is there a way I can take apart a better 92mm fan and put it into the zalman?
