D
Deleted member 72990
Guest
Hi guys,
looking in my sig you can see my speaker array. what is the best way to corner load my subs? i currenly have the promedia sub stacked on top of the mtx. my room is about a 12x10' rectangle, not very big. i noticed the farther away i stand from the sub (one side of room to the other) yields the best results, but i cant set up my room that way.
enough babling. my question is this. how do i corner load the promedia sub? it has speakers on both sides and a port on back. if i corner load it, the one woofer and port muffle against the wall. i dont know how else to load it. the mtx sub is downfiring and the massive air coming out the bottom also muffles against the wall. what do i do? i'd like the great bass response but without the crappy muffling against the wall.
