TrueChaos99
- Nov 26, 2007
I'm confused over which one of these two programs is actually reading the temperature correctly for my E8400.
I'm on the stock intel cooler, and coretemp read 45C idle and 65C load, as the maximum. Occasionally one of the cores would be at a different temp, but not usually. Everest reads the same as coretemp. RealTemp on the other hand, reads 10C lower than coretemp. Which one of these is correct? I'd like to believe realtemp, as I want to run 3.6 on the stock cooler -- this gives temps of 70C in CoreTemp and 60C in RealTemp. If Coretemp is right, I'll back off until I can afford a better cooler, but I'm more inclined to believe realtemp. This is because it just doesn't make sense that a processor would hit 65C load under 100% stock conditions. My case is not cramped, and does have good airflow. Which one is correct?
