CoreTemp 95 versus 95.4
Peepaw
Well the new version of coretemp is out, 95.4.
Everyone has been saying that the temps are too low to be real. I think the latest version is pretty close. Sure all those low low temps look cool but they are not realistic.
tjunction raised to 100°
First shot is version 95.
Second shot is version 95.4
Is this version compatible with Vista x64?
I would love to use coretemp, but I know that 95 is NOT compatible. It simply crashes anytime I try to use it.
I guess you need to try it. Below is a list of fixes with this version.
What's new:
Version 0.95.4 - 22nd August, 2007
- Fix: Core Temp causes restarts/BSODs on start.
- Fix: Core Temp causes hard shutdowns on some AMD systems.
- Fix: System tray icons are black squares on less than 32bit desktops.
- Fix: Some other minor bugs fixed.
- Add: Support new Intel CPUs.
- Fix: Revision F Turion/Turion X2 detected wrong.
- Fix: Core Temp fully loads one core on a dual core AMD CPU.
- Fix: Core Temp crashes on Dual Core Opteron 200 series systems.
- Fix: Core Temp misdetected certain Dual Core Opteron CPUs.
- Fix: Must set Core Temp to run as Administrator in Vista.
- Fix: Can't see Core Temp GUI if Core Temp was last closed minimized.
- Fix: C2D L2 rev. report very low temperatures. (Tjmax to 100C)
- Fix: Core Temp reported wrong temps after a while. (Driver conflict)
- Fix: Core Temp reported Max VID on Intel CPUs. (Now shows current)
- Add: Show temperature in System tray.
- Add: Manual refresh option by pressing F5 or "File" Menu.
- Add: Show "Delta to Tjunction" temperature for Core 2 CPUs.
- Add: Support for latest Intel and AMD CPUs.
- Add: Minimize/Restore option in system tray icon right click.
- Add: Save last window position.
- Add: Prevent 2 instances of Core Temp from launching.
- Change: Rewritten Intel CPU recognition code.
- Change: Core 2 Duo codename change to Conroe-2M from Allendale.
- Change: Pop up bubble-window with temperatures removed.
- Change: Not Beta status anymore.
The new CoreTemp matches up exactly with my supplied temp monitoring software from MSI..........:D That's good to know.
You still need to disable driver signing to get this version to run in Vista x86-64
