Core_17
Toconator
[H]ard DCOTM January 2026
GPU Core_17 - just got one of these today and : "The program can't start because libglib-2.0-0.dll is missing" . I hate when it does that ! :rolleyes:
Seems to me it deserves to be reported to the developer.
One shouldn't be satisfying DLL dependencies manually...
Would you like a moment alone with V7.x.x?:p
Toconator, Can you please chime into this FF thread. Someone else is having the same issue. I don't think anyone tested on the v6 client.
Edit: Link to this thread posted over there at FF in the beta thread.
http://foldingforum.org/viewtopic.php?f=66&t=23845&view=unread#p238525
Yeah, v6.41 client with -betateam flag set. Seems this was intended for v7 clients and not tested on v6.41 Simply copying the missing dll from a v7 client not successful. I'm removing the beta flag until this is fixed.
what driver version do you have and on what card?
The problem is, it is fixed - upgrade to the v7 client. I doubt you will see a v6 fix for anything related to GPUs (or anything else for that matter.)
Patriot: driver 306.97 (newer causes stuttering in SoaSE) on GTX 550Ti
musky: haven't been able to run v7 as a service on CPU without it wanting to also run as a service on GPU which is not possible with Win Vista/7/8. v7 errors out and hafta run v6 client for GPU anyways.
Should the 17 core restore the Fermi Performance as well as raise the Kepler performance?
At the moment no, All Nvidia GPU's prefer Cuda programs to ones coded with openCL - which is what core 17 uses, Fermi performance is better than Kepler but AMD are now back in the game as they are running very well now. Nv also need to do some work on their drivers
So does that mean the v7 client will auto detect AMD GPUs now such as the 6000 series? I got a friend with a 2500k, 6950 and 6990 setup in his PC that I'm sure I could talk into running FAH.
coded with openCL - which is what core 17 uses ...
VERY interesting, wonder what folding will be like on newer more efficient 7xxx series cards? 7770's are power sippers and fairly inexpensive too ...
I'd guess pretty terrible. Especially with the units having QRB (and tuned for GRB), low level cards (like the 7770 with low compute and small memory bus) are at a severe disadvantage.
Memory is currently not used very heavily....
Fire it up and see. GCN is a beast.
Are there any special flags to get Core_17 units? Currently running 7.3.6 on a Windows 7 box with a Radeon 7870 XT. Currently only getting Core_16 units which are only good for 5000 PPD.
NVM...figured it out. :)
I have picked up a few core_17 units since I've seen this thread. Average TPF is 3m50s @ ~ 23.5kppd. One beautiful thing about this core is that usually my GPU is sitting at 68-72C when folding, with this core, Im steady at 54C! (both instances using 100% GPU)
It would be useful if you mentioned what GPU you are talking about.
Sorry about that, I should know by now not to rely on signatures all the time (mobile [h] doesn't show them and that's what I'm on most of the time)
GTX 670 @ 1150 core 3105 mem with the fan at 80% while I'm at work.
And I meant both instances as in the GPU was being used 100% when the comparison temps were taken
Hmmm, getting a bunch of bad WU's or somethings up.
Code:
*********************** Log Started 2013-03-13T02:04:58Z ***********************
02:04:58:************************* Folding@home Client *************************
02:04:58:      Website: http://folding.stanford.edu/
02:04:58:    Copyright: (c) 2009-2013 Stanford University
02:04:58:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:04:58:         Args:
02:04:58:       Config: C:/Users/Owen/AppData/Roaming/FAHClient/config.xml
02:04:58:******************************** Build ********************************
02:04:58:      Version: 7.3.6
02:04:58:         Date: Feb 18 2013
02:04:58:         Time: 15:25:17
02:04:58:      SVN Rev: 3923
02:04:58:       Branch: fah/trunk/client
02:04:58:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
02:04:58:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
02:04:58:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
02:04:58:     Platform: win32 XP
02:04:58:         Bits: 32
02:04:58:         Mode: Release
02:04:58:******************************* System ********************************
02:04:58:          CPU: Intel(R) Core(TM) i7 CPU 950 @ 3.07GHz
02:04:58:       CPU ID: GenuineIntel Family 6 Model 26 Stepping 5
02:04:58:         CPUs: 8
02:04:58:       Memory: 6.00GiB
02:04:58:  Free Memory: 2.88GiB
02:04:58:      Threads: WINDOWS_THREADS
02:04:58:  Has Battery: false
02:04:58:   On Battery: false
02:04:58:   UTC offset: -4
02:04:58:          PID: 15676
02:04:58:          CWD: C:/Users/Owen/AppData/Roaming/FAHClient
02:04:58:           OS: Windows 7 Ultimate
02:04:58:      OS Arch: AMD64
02:04:58:         GPUs: 1
02:04:58:        GPU 0: ATI:5 Tahiti XT [Radeon HD 7970]
02:04:58:         CUDA: Not detected
02:04:58:Win32 Service: false
02:04:58:***********************************************************************
02:04:58:<config>
02:04:58:  <!-- Folding Slot Configuration -->
02:04:58:  <power v='full'/>
02:04:58:
02:04:58:  <!-- Network -->
02:04:58:  <proxy v=':8080'/>
02:04:58:
02:04:58:  <!-- User Information -->
02:04:58:  <passkey v='********************************'/>
02:04:58:  <team v='734'/>
02:04:58:  <user v='Activate:_AMD'/>
02:04:58:
02:04:58:  <!-- Folding Slots -->
02:04:58:  <slot id='0' type='GPU'>
02:04:58:    <client-type v='beta'/>
02:04:58:  </slot>
02:04:58:</config>
02:04:58:Trying to access database...
02:04:58:Successfully acquired database lock
02:04:59:Enabled folding slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970]
02:04:59:WU00:FS00:Starting
02:04:59:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Owen/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/beta/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 703 -lifeline 15676 -checkpoint 15 -gpu 0 -gpu-vendor ati
02:04:59:WU00:FS00:Started FahCore on PID 10164
02:04:59:WU00:FS00:Core PID:15800
02:04:59:WU00:FS00:FahCore 0x17 started
02:04:59:WU00:FS00:0x17:*********************** Log Started 2013-03-13T02:04:59Z ***********************
02:04:59:WU00:FS00:0x17:Project: 7662 (Run 2, Clone 0, Gen 13)
02:04:59:WU00:FS00:0x17:Unit: 0x00000011ff3d483551391279e8c15b75
02:04:59:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
02:04:59:WU00:FS00:0x17:Machine: 0
02:04:59:WU00:FS00:0x17:Reading tar file state.xml
02:04:59:WU00:FS00:0x17:Reading tar file system.xml
02:04:59:WU00:FS00:0x17:Reading tar file integrator.xml
02:04:59:WU00:FS00:0x17:Reading tar file core.xml
02:04:59:WU00:FS00:0x17:Digital signatures verified
02:05:07:WU00:FS00:0x17:Core and Checkpoint energies do not match.
02:05:10:WU00:FS00:0x17:ERROR:exception: Expected 77325.5, found 1.#QNAN
02:05:10:WU00:FS00:0x17:Saving result file logfile_01.txt
02:05:10:WU00:FS00:0x17:Saving result file badCoreState.xml
02:05:11:WU00:FS00:0x17:Saving result file badCoreStateCMMotionRemover.xml
02:05:11:WU00:FS00:0x17:Saving result file badCoreStateHarmonicAngleForce.xml
02:05:12:WU00:FS00:0x17:Saving result file badCoreStateHarmonicBondForce.xml
02:05:12:WU00:FS00:0x17:Saving result file badCoreStateNonbondedForce.xml
02:05:12:WU00:FS00:0x17:Saving result file badCoreStatePeriodicTorsionForce.xml
02:05:12:WU00:FS00:0x17:Saving result file log.txt
02:05:13:WU00:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
02:05:13:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
02:05:13:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:7662 run:2 clone:0 gen:13 core:0x17 unit:0x00000011ff3d483551391279e8c15b75
02:05:13:WU00:FS00:Uploading 1021.55KiB to 171.67.108.149
02:05:13:WU00:FS00:Connecting to 171.67.108.149:8080
02:05:14:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
02:05:14:WU01:FS00:News: Welcome to Folding@Home
02:05:14:WU01:FS00:Assigned to work server 171.67.108.149
02:05:14:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970] from 171.67.108.149
02:05:14:WU01:FS00:Connecting to 171.67.108.149:8080
02:05:15:WU01:FS00:Downloading 1.62MiB
02:05:16:WU01:FS00:Download complete
02:05:16:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:7662 run:29 clone:8 gen:13 core:0x17 unit:0x00000011ff3d4835513925304a97ad8b
02:05:16:WU01:FS00:Starting
02:05:16:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Owen/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/beta/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 703 -lifeline 15676 -checkpoint 15 -gpu 0 -gpu-vendor ati
02:05:16:WU01:FS00:Started FahCore on PID 17376
02:05:16:WU01:FS00:Core PID:11256
02:05:16:WU01:FS00:FahCore 0x17 started
02:05:17:WU01:FS00:0x17:*********************** Log Started 2013-03-13T02:05:16Z ***********************
02:05:17:WU01:FS00:0x17:Project: 7662 (Run 29, Clone 8, Gen 13)
02:05:17:WU01:FS00:0x17:Unit: 0x00000011ff3d4835513925304a97ad8b
02:05:17:WU01:FS00:0x17:CPU: 0x00000000000000000000000000000000
02:05:17:WU01:FS00:0x17:Machine: 0
02:05:17:WU01:FS00:0x17:Reading tar file state.xml
02:05:17:WU01:FS00:0x17:Reading tar file system.xml
02:05:17:WU01:FS00:0x17:Reading tar file integrator.xml
02:05:17:WU01:FS00:0x17:Reading tar file core.xml
02:05:17:WU01:FS00:0x17:Digital signatures verified
02:05:19:WU00:FS00:Upload 62.65%
02:05:22:WU00:FS00:Upload complete
02:05:22:WU00:FS00:Server responded WORK_ACK (400)
02:05:22:WU00:FS00:Cleaning up
02:05:25:WU01:FS00:0x17:Core and Checkpoint energies do not match.
02:05:27:WU01:FS00:0x17:ERROR:exception: Expected 78510.8, found 1.#QNAN
02:05:27:WU01:FS00:0x17:Saving result file logfile_01.txt
02:05:27:WU01:FS00:0x17:Saving result file badCoreState.xml
02:05:28:WU01:FS00:0x17:Saving result file badCoreStateCMMotionRemover.xml
02:05:28:WU01:FS00:0x17:Saving result file badCoreStateHarmonicAngleForce.xml
02:05:29:WU01:FS00:0x17:Saving result file badCoreStateHarmonicBondForce.xml
02:05:29:WU01:FS00:0x17:Saving result file badCoreStateNonbondedForce.xml
02:05:29:WU01:FS00:0x17:Saving result file badCoreStatePeriodicTorsionForce.xml
02:05:29:WU01:FS00:0x17:Saving result file log.txt
02:05:30:WU01:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
02:05:30:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
02:05:30:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:7662 run:29 clone:8 gen:13 core:0x17 unit:0x00000011ff3d4835513925304a97ad8b
02:05:30:WU01:FS00:Uploading 1006.38KiB to 171.67.108.149
02:05:30:WU01:FS00:Connecting to 171.67.108.149:8080
02:05:30:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
02:05:31:WU00:FS00:News: Welcome to Folding@Home
02:05:31:WU00:FS00:Assigned to work server 171.67.108.149
02:05:31:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970] from 171.67.108.149
02:05:31:WU00:FS00:Connecting to 171.67.108.149:8080
02:05:31:WU00:FS00:Downloading 1.62MiB
02:05:33:WU00:FS00:Download complete
02:05:33:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:7662 run:22 clone:16 gen:9 core:0x17 unit:0x0000000dff3d48355139207a8c5b10e1
02:05:33:WU00:FS00:Starting
02:05:33:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Owen/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/beta/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 703 -lifeline 15676 -checkpoint 15 -gpu 0 -gpu-vendor ati
02:05:33:WU00:FS00:Started FahCore on PID 1376
02:05:33:WU00:FS00:Core PID:13316
02:05:33:WU00:FS00:FahCore 0x17 started
02:05:33:WU00:FS00:0x17:*********************** Log Started 2013-03-13T02:05:33Z ***********************
02:05:33:WU00:FS00:0x17:Project: 7662 (Run 22, Clone 16, Gen 9)
02:05:33:WU00:FS00:0x17:Unit: 0x0000000dff3d48355139207a8c5b10e1
02:05:33:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
02:05:33:WU00:FS00:0x17:Machine: 0
02:05:33:WU00:FS00:0x17:Reading tar file state.xml
02:05:33:WU00:FS00:0x17:Reading tar file system.xml
02:05:34:WU00:FS00:0x17:Reading tar file integrator.xml
02:05:34:WU00:FS00:0x17:Reading tar file core.xml
02:05:34:WU00:FS00:0x17:Digital signatures verified
02:05:36:WU01:FS00:Upload 69.95%
02:05:39:WU01:FS00:Upload complete
02:05:39:WU01:FS00:Server responded WORK_ACK (400)
02:05:39:WU01:FS00:Cleaning up
02:05:42:WU00:FS00:0x17:Core and Checkpoint energies do not match.
02:05:44:WU00:FS00:0x17:ERROR:exception: Expected 73324.1, found 1.#QNAN
02:05:44:WU00:FS00:0x17:Saving result file logfile_01.txt
02:05:44:WU00:FS00:0x17:Saving result file badCoreState.xml
02:05:45:WU00:FS00:0x17:Saving result file badCoreStateCMMotionRemover.xml
02:05:45:WU00:FS00:0x17:Saving result file badCoreStateHarmonicAngleForce.xml
02:05:46:WU00:FS00:0x17:Saving result file badCoreStateHarmonicBondForce.xml
02:05:46:WU00:FS00:0x17:Saving result file badCoreStateNonbondedForce.xml
02:05:46:WU00:FS00:0x17:Saving result file badCoreStatePeriodicTorsionForce.xml
02:05:47:WU00:FS00:0x17:Saving result file log.txt
02:05:47:WU00:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
02:05:47:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
02:05:47:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:7662 run:22 clone:16 gen:9 core:0x17 unit:0x0000000dff3d48355139207a8c5b10e1
02:05:47:WU00:FS00:Uploading 1012.83KiB to 171.67.108.149
02:05:47:WU00:FS00:Connecting to 171.67.108.149:8080
02:05:47:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
02:05:48:WU01:FS00:News: Welcome to Folding@Home
02:05:48:WU01:FS00:Assigned to work server 171.67.108.149
02:05:48:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970] from 171.67.108.149
02:05:48:WU01:FS00:Connecting to 171.67.108.149:8080
02:05:48:WU01:FS00:Downloading 1.62MiB
02:05:50:WU01:FS00:Download complete
02:05:50:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:7662 run:28 clone:5 gen:19 core:0x17 unit:0x00000016ff3d48355139246c79150aab
02:05:50:WU01:FS00:Starting
02:05:50:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Owen/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/beta/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 703 -lifeline 15676 -checkpoint 15 -gpu 0 -gpu-vendor ati
02:05:50:WU01:FS00:Started FahCore on PID 10440
02:05:50:WU01:FS00:Core PID:15544
02:05:50:WU01:FS00:FahCore 0x17 started
02:05:50:WU01:FS00:0x17:*********************** Log Started 2013-03-13T02:05:50Z ***********************
02:05:50:WU01:FS00:0x17:Project: 7662 (Run 28, Clone 5, Gen 19)
02:05:50:WU01:FS00:0x17:Unit: 0x00000016ff3d48355139246c79150aab
02:05:50:WU01:FS00:0x17:CPU: 0x00000000000000000000000000000000
02:05:50:WU01:FS00:0x17:Machine: 0
02:05:50:WU01:FS00:0x17:Reading tar file state.xml
02:05:50:WU01:FS00:0x17:Reading tar file system.xml
02:05:51:WU01:FS00:0x17:Reading tar file integrator.xml
02:05:51:WU01:FS00:0x17:Reading tar file core.xml
02:05:51:WU01:FS00:0x17:Digital signatures verified
02:05:53:WU00:FS00:Upload 63.19%
02:05:56:WU00:FS00:Upload complete
02:05:56:WU00:FS00:Server responded WORK_ACK (400)
02:05:56:WU00:FS00:Cleaning up
02:05:59:WU01:FS00:0x17:Core and Checkpoint energies do not match.
02:06:01:WU01:FS00:0x17:ERROR:exception: Expected 75917.3, found 1.#QNAN
02:06:01:WU01:FS00:0x17:Saving result file logfile_01.txt
02:06:01:WU01:FS00:0x17:Saving result file badCoreState.xml
02:06:01:WU01:FS00:0x17:Saving result file badCoreStateCMMotionRemover.xml
02:06:02:WU01:FS00:0x17:Saving result file badCoreStateHarmonicAngleForce.xml
02:06:02:WU01:FS00:0x17:Saving result file badCoreStateHarmonicBondForce.xml
02:06:03:WU01:FS00:0x17:Saving result file badCoreStateNonbondedForce.xml
02:06:03:WU01:FS00:0x17:Saving result file badCoreStatePeriodicTorsionForce.xml
02:06:03:WU01:FS00:0x17:Saving result file log.txt
02:06:03:WU01:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
02:06:04:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
02:06:04:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:7662 run:28 clone:5 gen:19 core:0x17 unit:0x00000016ff3d48355139246c79150aab
02:06:04:WU01:FS00:Uploading 1022.96KiB to 171.67.108.149
02:06:04:WU01:FS00:Connecting to 171.67.108.149:8080
02:06:04:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
02:06:04:WU00:FS00:News: Welcome to Folding@Home
02:06:04:WU00:FS00:Assigned to work server 171.67.108.149
02:06:04:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970] from 171.67.108.149
02:06:04:WU00:FS00:Connecting to 171.67.108.149:8080
02:06:05:WU00:FS00:Downloading 1.62MiB
02:06:06:WU00:FS00:Download complete
02:06:06:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:7662 run:11 clone:18 gen:9 core:0x17 unit:0x0000000cff3d4835513918e580299b21
02:06:06:WU00:FS00:Starting
02:06:06:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Owen/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/beta/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 703 -lifeline 15676 -checkpoint 15 -gpu 0 -gpu-vendor ati
02:06:06:WU00:FS00:Started FahCore on PID 11732
02:06:07:WU00:FS00:Core PID:11416
02:06:07:WU00:FS00:FahCore 0x17 started
02:06:07:WU00:FS00:0x17:*********************** Log Started 2013-03-13T02:06:07Z ***********************
02:06:07:WU00:FS00:0x17:Project: 7662 (Run 11, Clone 18, Gen 9)
02:06:07:WU00:FS00:0x17:Unit: 0x0000000cff3d4835513918e580299b21
02:06:07:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
02:06:07:WU00:FS00:0x17:Machine: 0
02:06:07:WU00:FS00:0x17:Reading tar file state.xml
02:06:07:WU00:FS00:0x17:Reading tar file system.xml
02:06:07:WU00:FS00:0x17:Reading tar file integrator.xml
02:06:07:WU00:FS00:0x17:Reading tar file core.xml
02:06:07:WU00:FS00:0x17:Digital signatures verified
02:06:10:WU01:FS00:Upload 68.82%
02:06:13:WU01:FS00:Upload complete
02:06:13:WU01:FS00:Server responded WORK_ACK (400)
02:06:13:WU01:FS00:Cleaning up
02:06:15:WU00:FS00:0x17:Core and Checkpoint energies do not match.
02:06:26:WU00:FS00:0x17:ERROR:exception: Expected 72929.9, found 1.#QNAN
02:06:26:WU00:FS00:0x17:Saving result file logfile_01.txt
02:06:26:WU00:FS00:0x17:Saving result file badCoreState.xml
02:06:26:WU00:FS00:0x17:Saving result file badCoreStateCMMotionRemover.xml
02:06:27:WU00:FS00:0x17:Saving result file badCoreStateHarmonicAngleForce.xml
02:06:27:WU00:FS00:0x17:Saving result file badCoreStateHarmonicBondForce.xml
02:06:27:WU00:FS00:0x17:Saving result file badCoreStateNonbondedForce.xml
02:06:27:WU00:FS00:0x17:Saving result file badCoreStatePeriodicTorsionForce.xml
02:06:28:WU00:FS00:0x17:Saving result file log.txt
02:06:28:WU00:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
02:06:28:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
02:06:28:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:7662 run:11 clone:18 gen:9 core:0x17 unit:0x0000000cff3d4835513918e580299b21
02:06:28:WU00:FS00:Uploading 1.01MiB to 171.67.108.149
02:06:28:WU00:FS00:Connecting to 171.67.108.149:8080
02:06:34:WU00:FS00:Upload 55.57%
02:06:39:WU00:FS00:Upload complete
02:06:39:WU00:FS00:Server responded WORK_ACK (400)
02:06:39:WU00:FS00:Cleaning up
i am getting the same with 2 6850's
Code:
03:21:32:WU05:FS02:0x17:ERROR:exception: Expected 71612.7, found 1.#QNAN
03:21:32:WU05:FS02:0x17:Saving result file logfile_01.txt
03:21:32:WU05:FS02:0x17:Saving result file badCoreState.xml
03:21:32:WU04:FS02:Upload 55.84%
03:21:33:WU05:FS02:0x17:Saving result file badCoreStateCMMotionRemover.xml
03:21:33:WU05:FS02:0x17:Saving result file badCoreStateHarmonicAngleForce.xml
03:21:34:WU05:FS02:0x17:Saving result file badCoreStateHarmonicBondForce.xml
03:21:34:WU05:FS02:0x17:Saving result file badCoreStateNonbondedForce.xml
03:21:35:WU05:FS02:0x17:Saving result file badCoreStatePeriodicTorsionForce.xml
03:21:35:WU05:FS02:0x17:Saving result file log.txt
03:21:36:WU05:FS02:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
03:21:36:WARNING:WU05:FS02:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
i thought it might be my overclock, turned that down to stock, no dice. also tried with crossfire enabled and disabled, no luck, was hoping to put my ati cards in the mix
edit, doesn't even hit the GPU, it fails while the CPU is loading core_17 into memory... weird.
^^I noticed some weirdness with my GPU activity with general usage, like scrolling through web pages was causing my GPU to spike. I wound up restarting the whole PC and it went back to normal, folding started up just fine.
still not working for me, still failing all WUs after adding the 6850's into the mix and restarting, made sure to flag them both as beta also...
Figured it out, was reading this page here: http://www.overclock.net/t/1367557/core-17-beta-wu
and it made me think, "i wonder what version my drivers are?"
just another reminder to keep your vid drivers up to date people :D i installed 13.1 and now have 2 6850's folding :D:D:D
I've been having issues with the 13.2's, which I read somewhere else are supposed to be better for folding. I don't know if its the drivers , or a bug with the core, but if I pause F@H I'll occasionally get strange behavior. It doesn't really manifest itself tangibly at desktop, but I can see regular jumps to 20-30% GPU usage just using firefox, and the core speed will jump up to full speed at the same time. Normally I just sit at 500mhz and get 1-5% GPU usage. When this starts to happen if I try to game my GPU usage gets pegged at 95+% in game and I get artifacting. This was also what was happening when I was getting all those bad WU errors. Restarting seems to cure it, but this is going to get old really fast as the PC with the 7970 in it is my primary gaming rig, I need to be able to pause F@H reliably on it without it screwing up my WU progress and requiring a restart every time. I guess I'll have to go back to the 13.1's and see if it happens again.
the forum post i linked recommends 13.2's for 7000 series, so that seems weird that you are having so much troubles, wouldn't hurt to go back to 13.1 to see if it helps
Parapeters to get core 17?
client-type
(and here?) ( now it`s advanced )
use "beta" without quotes
bigted - what kind of PPD are you getting on your 6850's individually? I'm trying to fold on my 6870, but it killed my CPU folding... was getting the same PPD on my system with and without GPU, so I decided it wasn't worth the power. My 6870 PPD was ~7000.
I saw this post ^^ and made me realize I probably haven't checked my drivers in a while. Sure enough I'm on 12.1. We'll see if 13.1 makes any difference. Downloading now.
my 6850's are OC'd to 850 on the core and are getting 6k ppd each so 7k sounds about right for a 6870.
after i updated to 13.1 and started using core_17, i see barely any activity on the CPU, pretty much only when it starts up or gets a new WU
Ok cool. I got 13.1 installed and my CPU utilization went from ~25% to ~0.5%. GPU drivers are key it seems.
I'll reevaluate the system PPD after a couple days. Thanks for the help.
Ok so I got the dreaded "missing libglib-2.0.0.dll" error message also. So thinking a had a bad HDD (read old,) I rebuilt the system. And now after completing just 3 WU's on the GPU I have it again! after reading this forum I know that it isn't my system. So here is the big question: What is the fix? Even if it's just a temporary work around. Currently my F@H system is just running on SMP. I new to folding so I need someone to walk me through a solution.
Here are my system specs: Win 7 Pro 64bit, Intel 980X, Asus Rampage II Extreme, GTX470 with 320.18 driver, 6Gig of 1866 RAM, FAH GPU Tracker V2 ver 3.54.
Thanks
HumanHunter
17 is weird. Not only is my system less usable while running it, but my PPD drops significantly.
