core2duo setup slow when reading from a disc?
Mizugori
I have a core2duo e6400, in a foxconn P9657AA, with 2x512 Kingston Valueram PC2-667. It runs great, but sometimes when it is 'busy' doing something, it performs less than I would expect it to. Especially whenever I do anything that involves reading from the disc drive, a new lite-on IDE combo dvd burner with lightscribe, it lags terribly. I.e. copying or installing from a disc takes ten years. And if I try to do anything else while it is copying from a disc or installing from a disc, it runs very slowly.
Maybe this is a stupid question, but shouldn't the dual cores be able to overcome this? If one core is sweating its ass off trying to copy from a disc, why can't I just use the other core to surf the net or something in the meantime? Am I missing something? Also, I think the disc drive may be a bottleneck, is there anything I can do to make it read faster? Or do I just have to get another drive, and if so, what would be really fast for copying/reading/installing from CDs and DVDs?
Also, I have tried installing things from image files via Alcohol 120%, and the speed was amazing. But when I tried to install the same thing from the actual disc, rather than an image of the disc, it was terribly slow.
Any advice?
Did you perhaps forget to install your chipset drivers? It's possible your IDE controller doesn't have the right drivers installed.
Well, you have to understand that copying / installing etc. will always be slower from drive than from disk or ram. I really don't know "how" slow it is on your system, but it definitely should be slow. C2D won't speed up optical drive's bandwidth.
I agree, but the entire system shouldn't slow down.
If your chipset drivers are installed, maybe the controller reverted the drive to PIO mode. This can happen and will make the computer lag anytime the drive is being used.
good call, check to see that DMA is enabled. just to clarify for the OP, that means going System properties (windows key+ pause/break) -> Hardware Tab -> Device Manager -> IDE ATA/ATAPI Controllers -> Right-click on an IDE controller and select properties -> advanced settings -> and the transfer modes should read Ultra DMA Mode 5
Try another cable. If you have one, try another drive. It should slow the entire system down. If another optical drive works fine, then the drive might need a firmware update. If your chipset drivers are installed, then try an older version or using the ms ide drivers.
This is an issue with the original JMicron JMB36X drivers. You have 2 options revert to the standard MS IDE drivers or get the latest from the JMicron web site.
ahhh i just downloaded it from the jmicron site; it hasnt been auth'd by windows yet so no wonder i couldnt get this update when i tried just updating the driver through device manager. but after installation and restart, i tried installing a game from CD, and I'm still having the same issue... :( It lags while installing StarCraft, jesus that's pathetic... ie even while I am using firefox, the mouse is lagging pretty badly because the starcraft installation is in progress.
I have had no issues with the latest drivers. What version did you install? Try reverting to the MS IDE drivers and see if you still have the problem. If you do, the cause is not with the IDE bus.
I am currently having this problem right now. I just built this system today, and the lag is horrible when installing and dragging items from either DVD ROM to the hard drive. Mouse movement is choppy, there's text lag, and movies/music are unplayable; way too choppy.
I have one IDE slot on this piece of shit mobo (regret purchasing it), so both RW/ROM drives are on one cable. Could that be the problem? I haven't updated the BIOS yet. I'm going to grab whatever chipset drivers that are available right now.
Should I have gone SATA for the drives? Is there a big difference?
This is very frustrating, considering that all of my backup data needs to be transfered onto this system via DVDs.
Can anyone give me any tips please? This is getting friggin' ridiculous. Specs are in my sig. I just built the system a few days ago.
I just reformatted and put the 2 250GB drives into RAID 0. The DVD drives are on one IDE cable; there is only one slot on the motherboard.
Video and audio acceleration are at full. I cannot play DVDs at all on this system. The sound stutters and the video chops. I have the latest audio and video drivers. Updated the chipset and the BIOS. I don't know what to do, I need ideas please.
Okay, I somehow managed to fix this totally. I reinstalled the latest JMicron drivers, then I noticed I was permanently set to PIO mode, so I uninstalled both primary and secondary controllers. After a reboot and re-activating Windows, both controllers were missing from the device manager. That's a problem, but I tested a DVD and I get perfect audio/video now. I put on an mp3 and started dragging a file from the DVD drives. Perfect. No lag whatsoever and the transfer rate is at optimal.
Problem fixed. Although, I cannot see my PCI controllers in the device manager.
