hydrogen18
- Oct 27, 2002
I have a core i7 860 that sits in my garage. The garage gets hot this time of year. I noticed CPU temps were getting above 50 C for the better part of the day.
I realized the cores were spending all day at 2.8 ghz. So I enabled Intel Speedstep in the BIOS. Now they sit at 1.2 ghz for most of the time. I also disabled fan speed control at the same time, so the CPU fan just sits at 3000 rpm. While I had the PC off I also blew some dust out of the CPU cooler (OEM) but it wasn't actually horribly dusty as the intake of the case has a foam filter on it.
However two strange things happened. After enabling speedstep, VCore started going all over the place. CPU temperature wasn't much lower. Then suddenly VCore leveled off completely and the CPU fan speed started changing. I don't think this should ever happen.
Here are graphs of the data over the past 24 hours. The gap in the graph is where I restarted so I could change the intel speedstep in the bios.
GRAPHS
The PSU is a Seasonic unit. I don't remember exactly what one but it was top rated here on the [H], was like $170 and came with a 7 year warranty.
The motherboard is an ASUS p7p55d LE.
The cpu is a Intel Core i7-860 Lynnfield Quad-Core 2.8GHz LGA 1156 95W Processor BX80605I7860.
What exactly is going on here? The OEM cooler is the original one from when the CPU was purchased almost immediately after release, so I could see the fan going bad. But the fact that VCore just changed at the same point in time as well doesn't make any sense. The way I got the SeaSonic PSU is that I had an Antec unit that was apparently bad for nearly 3.5 years because during that whole time I could only get hard drives to last about 180 days before dying. Ever since that PSU died all my HDDs have been fine.
GRAPHS
