Sure can, it has read my voltage from way back in my early P4 days.... Look again, Core temp reads a static 1.134v for meYou can't get VID information from CPU-Z.
You need CoreTemp or Everest. (Under Everest, VID is represented by the Core Voltage tag. Note that this bit of info may only be available on the paid version.)
Lastly, if you see that your VID fluctuates with either program, or is considerably under 1.2 with a 65-nm processor, then you likely have Speedstep enabled. Disable Speedstep for an accurate reading.
