I've been using Core Temp to monitor my E6700 (at stock) and have noticed a large inconsistency in the temps it reports at different times. The temps it has reported at idle and load have varied by as much 15 degrees. (The lowest I've seen from core 0 has been 41 idle / 50 load, and the highest 52 idle / 65 load. The temps of core 1 have been around 0-2 degrees lower than core 0. Load temps came from ~1 hour of Orthos.)
I probably wouldn't be too concerned about what's going on if I didn't see temps like 65 load. This seems too high.
To my knowledge, nothing is changing that would cause this fluctuation in temps. It also hasn't been a matter of the temps going from high to low or vice versa. I'm using Asus PC Probe II to monitor temps as well, and what it reports has been fairly consistent in comparison.
I have the E6700 on an Asus P5N32-SLI Premium mobo and I'm using a Zalman CNPS9500 cooler. Is there something about the nforce chipset that would cause the inconsistency in what Core Temp reports? (I apologize if that's a dumb question.) If not, what else could be responsible for the inconsistency?
