Neither TAT nor core temp will work. i have vista 64. tat when i opened briefly flashes on screen then closes, core temp says cannot load driver and never starts. wtf????
In order for some of these tools to install and work with Vista the following procedure has to be done. XP people should skip this.
64-bit Vista needs steps 1 and 2
32-bit Vista needs just step 2 (but if it does not work, restart and do steps 1 and 2
Here is a web page that describes what must be done: http://www.alcpu.com/forums/viewtopic.php?t=211
In case the web page is not available.
Step 1:
Restart your system, and start hitting the F8 key until you get to the Windows boot menu.
Select "Disable Driver Signature Enforcement"
Hit the Enter key and Vista will continue to load.
Step 2:
Go to your "OC utils" folder and right click on each program and select "Properties". In properties go to the "Compatibility" tab and check "Run this program as an Administrator".
64-bit Vista users will have to do step 1 every time they start Vista and want to use these programs.
32-bit Vista users and step 2 for 64-bit Vista users, I am not sure, you will find out quick enough
speedfan shows the exact same thing for my temps as core temp does, 34'C idle. silly people saying F10 bios reported temps wrong, glad I stuck with F10.
