I am upgrading my Q6600 build that i put together back in December 2007 for gaming. I plan to keep this new build for awhile, I am going to be keeping pretty much everything except the MOBO,CPU,RAM, HSF, tell me how this looks? I am pretty sure it is going to be a kick ass build for gaming.
I have everything except the MOBO,CPU,RAM,HSF which will run me about $722 from newegg. I thik this is a pretty good build and upgrade that should last me awhile.
Does anyone see any problems with it? the PSU should be able to handle the new Core i7 and everything else right?
Antec 900 case( upgrading to non blue led case fans)
ASUS P6T Deluxe V2 http://www.newegg.com/Product/Product.aspx?Item=N82E16813131365
Intel Core i7 920 Nehalem 2.66GHz http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202
OCZ Gold 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 http://www.newegg.com/Product/Product.aspx?Item=N82E16820227365
COOLER MASTER V8 HSF http://www.newegg.com/Product/Product.aspx?Item=N82E16835103055
EVGA 9800GX2( Will upgrade to new generation DX11 card when it comes out)
EVGA 8800GS( Dedicated PhysX)
BFG Tech ES SERIES ES-800 800W PSU
Lite-On 20x LH-20A1L DVD Drive
2X Western Digital Raptor WD1500ADFD 150GB( RAID 0 OS/BOOT DRIVE)
Sound Blaster Xfi Xtreme Gamer fatality edition PCI sound card
Windows Vista 64 Ultimate( Maybe
