Core i7 Rig
ImAgainstIt
Hi, want to build a new rig, preferably i7..
Gaming
upto $1200 Canadian + Tax/shipping
3) Where do you live?
Edmonton, Canada
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
I will need a Mobo, Ram, CPU.
Power Supply - Corsair HX 1000W
Sound Card 1 - Creative X-Fi Champion
Sound Card 2 - Asus Xonar Essence STX
Video Card - evga GTX 275
Tuner - Hauppauge 1800
Hdd's - Seagate 500gb/1.5tb
dvd / case / keyboard / mouse i have.
6) Will you be overclocking?
Yes
Samsung 24" / 20"
Within the next two months
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Sli Possibly at a later date,
Atleast 2x PCIe X1 or X8 slots
10) Do you already have a legit and reusable/transferable OS key/license?
Yes.
Thanks for the help
Thanks alot for the suggestions, some questions though, how does that ram compare to the OCZ/Patriot/Corsair equiveleants and what about these motherboards
Asus P6T Deluxe V2 X58 w/ TripleDDR3 2000, 7.1 Audio, Dual Gigabit Lan, 1394, PCI-E, CrossFireX/ SLI
http://www.memoryexpress.com/Products/PID-MX23529(ME).aspx
Gigabyte GA-EX58-UD5 w/ TripleDDR3 2000, 7.1 Audio, Dual Gigabit Lan, 1394, PCI-E, 3-way CrossFireX/ SLI
http://www.memoryexpress.com/Products/PID-MX22584(ME).aspx
Also, the PCI-E slots should be fine, my two components with x1 will work in the x4 and x8's.
Thanks
The RAM is very good. It runs 8-8-8-24 @ 1.65v and shouldn't be much different from the OCZ/Patriot/Corsair equivalents. AFAIK, it uses Samsung DRAM chips.
Good motherboard.
I'm using this motherboard and am very satisfied. The reason I suggested the P6T was so you can save money. There aren't many significant advantages, and most X58 boards (in this price range) are quite similar. The major differences are brand preferences and BIOSes. That being said, I like my Gigabyte and it has better northbridge cooling relative to some of the less expensive X58 boards.
Ok Thanks alot for all the answers, but the only thing now is which of the two motherboards should I go with ? I've never used either brand and they're only $10 difference.
After much reviewing and research, I chose the Gigabyte EX58-UD5 over the ASUS P6T Deluxe. You can read the reviews and decide, but they're pretty much on par at most times.
