Apr 1, 2012 #1 J JekylHyde n00b Joined Mar 30, 2012 Messages 24 Hi why in the device manager i see as i have 4 cpu's? i have Core i3-2120 & what is the difference between Cores & Threads?
Apr 1, 2012 #2 DejaWiz Fully [H] 2FA Joined Apr 15, 2005 Messages 22,091 It will show as four cores since it's a dual core with HyperThreading. 2 cores, 4 threads. Allows a core to essentially process 2 streams, or threads, of data concurrently.
Apr 1, 2012 #4 DejaWiz Fully [H] 2FA Joined Apr 15, 2005 Messages 22,091 Indeed it does. 6C + HT shows 12, and so on.
Apr 1, 2012 #6 DejaWiz Fully [H] 2FA Joined Apr 15, 2005 Messages 22,091 You're welcome. Oh, and welcome to the [H]orde!
Apr 1, 2012 #7 P paperwastage [H]ard|Gawd Joined Jul 12, 2009 Messages 1,131 though threads will be slower than actual cores... depending on the application you use, might be 15-30%, might even be negative (switching threads has higher overhead than having fewer threads)
