Core 2 rig
what is your budget...if it can be any higher then get a new mobo...
You got my approval, but that DFI boards needs a bigger north bridge HS. If you have good air flow through the case you already have then it should be good. If your getting a new case make sure u put alot of fans in it :D
What would you recommend for a mobo then. Only reason I was choosing DFI was due to the great overclocking and stability results from my NF4 board.
